JeffHWI
Jul 27, 2018Guide
R7000P firmware 1.3.1.44 breaks Access Control and Attached Devices
Since upgrading my R7000P to firmware 1.3.1.44, I can no longer see attached devices, and have no way to manage them via Access Control. Before the upgrade to 1.3.1.44, I had Access Control enabled a...
- Aug 04, 2018
BUT, after a couple more reboots things were not visible again. So it looks like reverting to 1.3.1.26 is the solution until the next firmware after 1.3.1.44.
paperbag
Jul 29, 2018Tutor
I have the same problem also. To add another bug to the list, if you look at Status on the home page, it said all the lan ports (eth0 - eth3) are down and not taking any traffic but it is taking traffic. Please fix.
