Old_Duffer
Apr 21, 2021Initiate
R7000P firmware issues, etc.
I've been messing with my R7000P, AC2300 most of the night. A connected device has been dropping it's connection. The connections have been working perfect for a year on all devices until now. The...
roger_h
May 27, 2021Aspirant
Noticed your post today. I will be trying the following soon The following is worth a try.
Completely avoiding the Smart Wizard | Answer | NETGEAR Support
Hope it helps and is not to late!. Roger
- RubixcubeAug 10, 2021Aspirant
Current firmware
Firmware Version
V1.3.3.140_10.1.75Symptoms
device keeps rebooting
2.4ghz gets 100 to 200 mb if that.
5ghz gets 200 mb to 230ish.....
direct connect (if router does not self reboot) gets almost 1 gig
biggest issue is rebooting and the fact the LOG file only stores the last 1to 4 hours then erases every time i log in so no way to capture what is going on with out doing Pcap capture using another network device. Cannot save log file either. This is stupid. Normal ppl do not know what any of this troubleshooting involves and in this case it would take a full debug to figure it out. It is NOT oh reboot device, reload firmware, its your network settings blah blah blah.
Firmware is all jacked, I have tried all versions and same issue, Router keeps rebooting
and I am not getting the speeds I should be getting over WiFi consistantly. This is very sad for a $350.00 router.
Before you even suggest or ask. Yes I have tested all devices against a different router and they work fine with that router, that router gives the speed it has in its specs. AT&T ONT Router.
So NO it is not my devices, i have 17 devices and same issue on all.
I will be dropping the firmware back down 1 version because that was the version with the least issues.
YOU NEED TO FIX YOUR FIRMWARE....
after this experience I will never be purchasing a router from this company ever again.
