klt212
Jul 17, 2021Tutor
R7000P Firmware Update V1.3.2.134_10.1.66
Hi, When I check for firmware updates, I constantly get a notification there are no updates. I am on V1.3.2.120 which is at least one or two updates behind. The most current version list on the Net...
- Jul 19, 2021
You can skip versions and go directly to the latest.
I highly recommend the manual update process if you're doing it over a hardwired connection.
This is usually what we recommend. When we see corrupt firmware issues, it tends to be when people did it from the app, updated with the automatic process, or did it over wifi.
Jul 19, 2021Guru - Experienced User
klt212
Jul 20, 2021Tutor
Thanks.
