klt212
Jul 17, 2021Tutor
R7000P Firmware Update V1.3.2.134_10.1.66
Hi, When I check for firmware updates, I constantly get a notification there are no updates. I am on V1.3.2.120 which is at least one or two updates behind. The most current version list on the Net...
- Jul 19, 2021
You can skip versions and go directly to the latest.
I highly recommend the manual update process if you're doing it over a hardwired connection.
This is usually what we recommend. When we see corrupt firmware issues, it tends to be when people did it from the app, updated with the automatic process, or did it over wifi.
Aug 08, 2021Guru - Experienced User
You shouldn't need to but you can try it.
klt212
Aug 08, 2021Tutor
In addition to Not seeing connected devices in the app, when I log into the router it shows all my devices as alowed but only a handful connected.I'm thinking I should roll back to 1.3.2.120. Wondering if I should try a reset first.This happened the last time I try to update firmware. I don't think I'm going to try this again!
- plemansAug 08, 2021Guru - Experienced User
I would try a factory reset before I'd try rolling back the firmware. Sometimes the firmware changes enough that old settings can cause issues.
- klt212Aug 08, 2021Tutor
Thanks.I am reluctant to do so Factory resets as I'm not sure I would put it back to the settings I had before doing upgrade.I will give this a try tomorrow. I appreciate all your help.
I forgot to add that while the Netgear app doesn't show Any devices connected, when I log into the router it does show a handful.However, it shows all the devices that are allowed but none are connected.All the devices that are allowed are actually connected. I've never seen this before this upgrade.
- sktn77aAug 12, 2021Virtuoso
Yep, attached devices is screwed up on the latest R7000 firmware, too.
