klt212
Jul 17, 2021Tutor
R7000P Firmware Update V1.3.2.134_10.1.66
Hi, When I check for firmware updates, I constantly get a notification there are no updates. I am on V1.3.2.120 which is at least one or two updates behind. The most current version list on the Net...
- Jul 19, 2021
You can skip versions and go directly to the latest.
I highly recommend the manual update process if you're doing it over a hardwired connection.
This is usually what we recommend. When we see corrupt firmware issues, it tends to be when people did it from the app, updated with the automatic process, or did it over wifi.
klt212
Aug 08, 2021Tutor
I forgot to add that while the Netgear app doesn't show Any devices connected, when I log into the router it does show a handful.However, it shows all the devices that are allowed but none are connected.All the devices that are allowed are actually connected. I've never seen this before this upgrade.
sktn77a
Aug 12, 2021Virtuoso
Yep, attached devices is screwed up on the latest R7000 firmware, too.
- klt212Aug 24, 2021Tutor
This is an update. This latest firmware update has done nothing but screw up my router.I have devices dropping regularly. Devices do not show up on the router or the app. Also, it's definitely not playing nice with my EAX20 Wifi extender.So I think I'm going to roll back to my previous version or at least one or two back. This is ridiculous.
