Steven_Beullens
Sep 22, 2018Tutor
R7000P goes offline every couple of days
Since a couple of weeks I end up in the situation that all clients are connected to the WiFi or wired network but can’t connect to the internet. The routerlogin.net configuration site shows no proble...
- Sep 22, 2018
Easiest to start with this:
Make a back up (.cfg) and save to your desktop. Then reset the device. If the .44 FW is stable, there is no need to downgrade.
shadowsports
Sep 22, 2018Hero
Greetings,
You are not the only person whom I've heard mention this behavior with 1.3.1.44. Before assuming its the router...
What is in front of the R7000P?
How is this device configured?
When the router is in a "working" but no internet to client's state, is the internet LED white?
Obviously the FW was updated, did you do this manually or was it automatic?
Has the router been reset since it was upgraded?
Start with this. Reset the router to defaults using the [Erase] button in the GUI. Make no changes except what is needed for internet.
Does the behavior still occur?
If it does, you have a few options. Reflash the existing FW manually. Do not use the Genie App or Auto-Check and Update feature. Or flash one version back and see if that resolves the issue. Things to keep in mind. Modem (configuration) if applicable can affect the routers behavior. Auto Check & Update introduces a potential point of failure and (while convienent) is not the preferred method to upgrade. Enabling the auto update feature is not always a good idea. Go to bed with working router, wake up to a headache. Upgrades should always be planned and done on your terms.
Resetting after a upgrade or flash is recommended when unexpected or undesireable behavior occurs. Flashing manually is always best. Do so from a computer connected via ethernet. The files below must be unzipped before you flash. You can flash forward or backwards to any FW supported by your router model.
Last, once the router is configured and functioning as you like, make a back up of its configuration. This too is done in the routers admin console and only takes a minute.
***EDIT, Just read though .44's release notes. Concerning to see this:
>> Fixes the issue where the firmware update fails when using the Windows genie desktop app or genie mobile app
Many prople assume and use Genie Desktop or App to upgrade. There was obviously a problem previously. More proof that manual update is safest.
Steven_Beullens
Sep 22, 2018Tutor
I didn't pay attention to the LED's on the device itself. I'll have to check next time it occurs (it'll happen soon enough ...).
Once that's clear I'll go through the steps you're suggesting. And most likely I'll start with downgrading the firmware right away. It's been high on my list of possible causes since I'm more or less certain this never happened with previous versions.
Thanks for the advice.
- shadowsportsSep 22, 2018Hero
- lepa71Sep 22, 2018Guide
My R7000 does the same thing. Mine is in bridge mode but just hangs there with no IU access.
- Steven_BeullensSep 28, 2018Tutor
After a week of flawless operation my router lost it again this morning. I reset it completely after taking a config backup. Since the reset it's been working fine but that's usually the case for the first day or two after a reboot.
The more unpleasant surprise was that the backup could not be read and restored. The whole process lacks the possibility to validate the backup really. So it's taken me an hour or so to get everything back to the settings as before.
And the second really annoying surprise was that the Circle parental control configuration was gone as well. Every single detail (profile, devices, limits, ...) had to be entered again from scratch.
If I ever need to do the same again I seriously doubt what I will do: throw it out or spend another couple of hours...
- shadowsportsSep 28, 2018Hero
Sorry to hear of your multiple issues which just further compunded an already unpleasant situation.
I've never had a .CFG file which could not be read. Admittedly I don't make them often. I've only ever needed one or two for a particular FW version and rarely if ever have had a need to restore. Lucky I guess.
Parental controls, never used them ( so again lucky). Worst I've ever had to do is restore an ACL and a few address reservations (about 30 devices in total). I keep a back up and a txt file so recovery isn't always painless, but is manageable for the most part.
Something you can try. After you have the device working, restart it gracefully using the reboot option (Advanced tab). Now make your back up (.cfg). Can't say this will for sure, but it always has for me.
Good Luck
