stubbyjames
May 10, 2021Aspirant
R7000P Guest Network and Printer with Allow guests to see each other and access my local network off
A couple of question about the guest network on R7000P. One. if I set advanced options for the router, i.e., turning off UPnP. Will this also be turned off for the guest networks? Two. If I t...
stubbyjames
I have a lot of iot devices, some which require ethernet, and just a couple of pc's and a printer. I was thinking it would be nice if I could put my pcs and printer on the guest network and everything else on the primary network. However, if I do this, it seems that I could not print from my pcs with the isolation option selected. I was looking for some way to set this up.
antinode
May 10, 2021Guru
> [...] I was thinking it would be nice [...]
Not an actual goal. _Why_ would that "be nice"?
> [...] guest network [...] primary network. [...]
It's really one network, with some optional firewall-like rules to
restrict communication involving "guest" clients. If you want
unrestricted communication with some device, then you don't want it to
be a "guest", and you don't want the device with which it communicates
to be a guest. Or you _do_ want that "Allow guests" option.
> [...] I was looking for some way to set this up.
Exactly what "this" is remains a mystery. "I want these devices
separate, but I want them to be able to communicate"? At least one of
us is confused.
