Joelski2
Jan 03, 2022Aspirant
r7000p junk exactly one year after buying
This router worked flawlessly for exactly one year. The moment the router was not supported i started experiencing multiple drops per day. I have read the threads at nauseam. I have guest and mu-m...
michaelkenward
Jan 04, 2022Guru - Experienced User
Joelski2 wrote:
It is a private label Box says Spectrum D3.1 2.5G eMTA
Google isn't definitive, but that looks like a standard cable-modem with voice. No built-in router ti make life complicated.
Joelski2
Jan 04, 2022Aspirant
Yes, I do not believe it is the modem. I have beenin this house for 6 months issue free until December. I actually went on Best Buy Website in November and gave router a 5* review because i was impressed with coverage in larger house and a year of no issues. Then the following month everything went to hell. It is like a planned obsolence. Upon googling and trying to fix myself because im just outside of support period i found numerous threads on here and reddit all experiencing the same exact problem. Knock on wood with the mu-mimo disables i have not had a drop in 24 hrs.
- michaelkenwardJan 04, 2022Guru - Experienced User
I have used the R7000P since it first appeared. No problems.
Perhaps Netgear is picking on you.
- Joelski2Jan 04, 2022Aspirant
haha fingers crossed this mu-mimo disable sol'n works
