repomannv's avatar
May 04, 2021
R7000P losing 2.4Ghz wireless completely after a few hours
Purchased R7000P December 2020; worked flawlessly for all wifi on both 2.4Ghz and 5.0 Ghz using default settings, latest firmware since new until 2 days ago when the 2.4Ghz wireless just stopped working;  rebooting the R7000P brings it back, and it works again for several hours, broadcasting SSID, assigning IP's via DHCP, authenticating, etc. and then poof, after a few hours, stops working, all the while 5.0Ghz continues working no problem.   I tried a few workarounds:
- disabling guest networks completely
- disabling mu-mimo feature
Neither had any affect.   Logging on the R7000P is worthless and shows nothing.   When it fails, it is still broadcasing the SSID on 2.4ghz, but any attempt to connect fails, no IP is assigned, client wifi devices tend to fail by saying "incorrect password" but 100% the password is correct, no log entries, so something is broken after the very very early handshaking.    I've read other reports on the community forum of similar failures, but other than downgrading firmware from reports 2 years ago, and those workarounds above, nothing else.   My assumption is the device is completely Fubar'ed and will need replacement.  I'll most likely request a hw replacement.
  • plemans's avatar
    What actual firmware version are you on?  (a number and not "the latest")
    Have you tried a factory reset and reinstall?
    • repomannv's avatar
      repomannv
      Tutor
      Thanks for the reply.  Firmware version is V1.3.1.64_10.1.36
      I have done a factory reset (hold button 7 seconds, power cycle, R7000P goes back to factory defaults, and then I set device pw, SSID, and wireless password, leaving all other settings as factory defaults.
      Immediately after factory reset, 2.4ghz did not work at all; I found through experimentation, that changing the 2.4ghz wireless channel setting from "auto" to a fixed number, like 4, 8, or 11  would start working immediately after "applying" the channel change, for about 1 minute, then freeze up again.  So, whatever is failing is not a "hard" failure, it can come back to life without a  power-cycle, but it doesn't live long.  Switching channels wakes up the 2.4Ghz, at least for a short time.
      I did not reflash the firmware image to the device as it was already loaded with the latest .36 firmware; I suppose the next thing to try would be doing a reflash, so I'll do that when I have time and continue to try random other things, and report back here.
      I'm not hopeful, this problem has been going on for years, reported by dozens of people across many different versions of firmware.   I think its a hardware issue, I think netgear knows what it is and has decided its not cost effective to fix it in this product, so they've gone silent about it.  It's likely some devices are just longer lived than others, if its because an individual component is wearing out, then its luck of the draw when it finally gives out, could be months, could be years.    Even if I get netgear to replace my R7000P, I would expect the replacement to fail eventually the same way, the only real solution will be to throw away the R7000P and replace it with something else.
      • plemans's avatar
        You're actually a bit behind on firmware.
        the current version is 1.3.2.134
        might be worth installing that over a hardwired connection and seeing how it works.
