BeebeYourself's avatar
Jul 17, 2017
R7000P not working after reset to default settings
Earlier today I reset my r7000p router to default/factory settings using the browser control panel. Now it turns on fine, all lights are normal, and both bands are broadcasting, but when I connect to ...
  • BeebeYourself's avatar
    Jul 21, 2017
    I never really figured out exactly what the problem was, but I did end up fixing it! I used an great freeware tool called "Complete Internet Repair." It basically fixes and resets everything there is in one go and also includes a lot of other good options. Here's the download link in case anyone else faces a similar issue:
    https://www.rizonesoft.com/downloads/complete-internet-repair/
    Thanks to everyone who tried to help me!
