BeebeYourself
Jul 17, 2017Aspirant
R7000P not working after reset to default settings
Earlier today I reset my r7000p router to default/factory settings using the browser control panel. Now it turns on fine, all lights are normal, and both bands are broadcasting, but when I connect to ...
- Jul 21, 2017
I never really figured out exactly what the problem was, but I did end up fixing it! I used an great freeware tool called "Complete Internet Repair." It basically fixes and resets everything there is in one go and also includes a lot of other good options. Here's the download link in case anyone else faces a similar issue:
https://www.rizonesoft.com/downloads/complete-internet-repair/
Thanks to everyone who tried to help me!
BeebeYourself
Jul 18, 2017Aspirant
Update: I was able to connect and configure the router with another computer. Now everything is working except for my computer. I still get the same messages. When I try to execute ipconfig /renew I get: "unable to connect to your DHCP server. Request has timed out." For whatever adapter Im using to connect. I'm using Windows 10 home. If anyone knows what the problem is I'd appriciate the help.
JamesGL
Jul 18, 2017NETGEAR Employee Retired
Hi BeebeYourself,
Try to disable and enable the adapter of your computer. Check for any updates.
