cmccaghren
Apr 19, 2019Aspirant
r7000p power blinking orange after failed update
I have read through some posts on this problem, is it just dead? it is just over a year old .
- Apr 19, 2019
> I have read through some posts on this problem, [...]
Think for a moment about how little useful unformation that
non-description conveys to the non-psychics in your audience.> [...] is it just dead?
Have you tried the TFTP recovery procedure?
antinode
Apr 19, 2019Guru
cmccaghren
I have attempted it a couple of times, the links in the procedure do not work
- antinodeApr 19, 2019Guru
> not workThe TFTP recovery procedure is a multi-step procedure with many
variables, and many opportunities for user error."attempted it" or "do not work" is not a useful problem description.
It does not say what you did. It does not say what happened when you
did it. As usual, showing actual actions with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.- cmccaghrenApr 20, 2019AspirantSorry to not be to your level. So I will give you the exact procedure I did .I took the piece of **bleep** Netgear threw it in the **bleep**ing trash and went and bought a Linksys. Is that detailed enough?
- antinodeApr 20, 2019Guru
> [...] Is that detailed enough?
It tells me all that I need to know.
- michaelkenwardApr 20, 2019Guru - Experienced User
It can take a little effort to get TFTP to work.
You might find it helpful to search for one of those YouTube videos:
unbrick my netgear router - Google Search
Take is slowly and pay attention to the exact details.
