cmccaghren
Apr 19, 2019Aspirant
r7000p power blinking orange after failed update
I have read through some posts on this problem, is it just dead? it is just over a year old .
- Apr 19, 2019
> I have read through some posts on this problem, [...]
Think for a moment about how little useful unformation that
non-description conveys to the non-psychics in your audience.> [...] is it just dead?
Have you tried the TFTP recovery procedure?
antinode
Apr 20, 2019Guru
> I have attempted it a couple of times, the links in the procedure do
> not work
The TFTP recovery procedure is a multi-step procedure with many
variables, and many opportunities for user error.
"attempted it" or "do not work" is not a useful problem description.
It does not say what you did. It does not say what happened when you
did it. As usual, showing actual actions with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
cmccaghren
Apr 20, 2019Aspirant
Sorry to not be to your level. So I will give you the exact procedure I did .I took the piece of **bleep** Netgear threw it in the **bleep**ing trash and went and bought a Linksys. Is that detailed enough?
- antinodeApr 20, 2019Guru
> [...] Is that detailed enough?
It tells me all that I need to know.
- myerswApr 20, 2019Master
cmccaghren wrote:
Sorry to not be to your level. So I will give you the exact procedure I did .I took the piece of **bleep** Netgear threw it in the **bleep**ing trash and went and bought a Linksys. Is that detailed enough?Hopefully you will have good luck with the Linksys. Every consumer grade router has firmware issues it seems. Cannot really check Asus forums for their 'normal' routers only their gaming routers. Others seem to have issues similar to NG. NG does not seem to be testing the firmware before pushing out IMHO. Almost like a it loads so ship it.
