Jim-Bob
Nov 20, 2021Follower
R7000P Readyshare (again) USB device 'Cannot be stopped right now'
This is a recurring issue with several Netgear routers with Readyshare, and there have been several replies to this question, but none of them are actually helpful. For example, there are no suggeste...
DavoDavoDavo
Jun 05, 2025Aspirant
Your post was quite informative, thank you...wasn't aware of the "log in from a non-windows device" strategy.
The symptom is caused by a network conversation between the router and the PC, and the PC having some open "file handles" on the drive. The file handles could be held by an application, from explorer, or from a "mapped network drive." I'm not sure why the Netgear's software does this, but the irritating behavior actually has some good thought behind it (not wanting to risk corrupted data on your USB drive). For me the main cure was to disconnect the mapped network drives (shares) that are on my PC before I try to safely disconnect the USB.
