O080O
Mar 16, 2021Aspirant
r7000P router cutting wifi speeds in half
Modem: CM1000 Router: R7000P Channel: auto My modem, when hardwired, is getting speeds around 500 mbps. When connecting the router to the modem, speeds are reduced by around 50%. The connection...
michaelkenward
Mar 17, 2021Guru - Experienced User
These are all wired tests? Wifi will not match wired.
Be sure to disable QoS on the router, along with other features that eat the router's processor power, like traffic metering.
O080O
Mar 17, 2021Aspirant
QoS & Traffic Monitoring were already are disabled.
