Alex101
Jun 30, 2018Aspirant
R7000P router dropping wifi and internet
My R7000P router which cost $300 has been giving me nothing but grief. Since I've had it for some reason it will drop wifi connection to my phone. It will drop connection to the internet. I've got the...
- Jul 05, 2018
Should i return the box for a refund?
Yes and get something totally different from another vendor.
Netgear has had the same firmware issues across all models for months now with no fixes in site .
All support does is say reset and reconfigure for every issue someone opens. Never make effort to figure out what is happening.
Got a r8000p cheap should someone be stupid enough to want it.
IMHO Netgear = Crap.
Blanca_O
Jul 04, 2018NETGEAR Employee Retired
Hi Alex101,
Welcome to NETGEAR Community!
Try resetting the router and reconfigure it to get back the connection.
Blanca
Community Team
myersw
Aug 05, 2018Master
Blanca_O wrote:
Hi Alex101,
Blanca
Community Team
Doesn't Netgear have any better answers then reset and reconfigure. That gets old for the end user quickly. In my experience with numerous routers, is if the firmware is right then the router will just run for months at a time, not just a few hours or days. My recent examples are my Asus rt-ac86u running Merlin firmware and the Netgear r7800 running LEDE. These routers just run and can be put on shelf and forgotten unlike the piece of junk R8000P I was lucky enough to sell. The rt-ac86u and r7800 with LEDE will run for months they way they are. The r7800 with Netgear firmware had issues by the way, before you ask. Have been envolved with routers since by first WRT54G back in 2006 so have seen a lot of them over the years.
Netgear needs to invest some money in their firmware engineers as it seems the current ones cannot fix issues that have been going on for months.
Just my $.02
