Jstrick33's avatar
Jstrick33
Nighthawk AC1750 Router (R6700v3) will not power on.
When I plug in the router and press the power button on the back, the Power light, and the 2.4Ghz, 5Ghz, Guest Wifi, and USB 3.0 lights all blink one time and then nothing happens.  I tried the reset...
  • Jstrick33's avatar
    Jstrick33
    Nov 09, 2023
    I think you're right.  I didn't realize it, but the cord is the wrong cord.  It goes to a motorola... I will try locating the correct power supply cord and try it again.  Thanks.
