PapaXDragon
May 23, 2021Tutor
R7000p stopped working
so a little context, got this used so its not orginal. i dont have the box it came with nor any of the manuals. So i was playing video games and i noticed that my internet was slow and it wasnt c...
- May 30, 2021
HOLY COW!!! IT FIXED IT!!!!
So this is how i ended up doing it
i took the downloaded file and moved it from my actual desktop to ThisPC> Local Disk (C:)> users> CarlJ> Desktop. and plased it there.
from there i followed this link https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
and from there i followed the instructions and it flipping worked.
I just wanna say thank you guys so much for the help!! stay safe with Coiv-19
May 23, 2021Guru - Experienced User
try using tftp or nmrpflash.
are you on windows? if so, follow this guide
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- PapaXDragonMay 23, 2021Tutor
thanks for the reply
i tried all the steps on (https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP)
1) but couldt make it past step 12 it said that it 'could not read from local file'. im not sure what to do after that?
2) I also tried the video and I couldnt make it work unless im missing something. i dont know if i need to input a password or what else.
i also enabled tftp
also i dont know how to use the git hub one that one seems too complex for me
- michaelkenwardMay 24, 2021Guru - Experienced User
That can happen if the firmware file isn't in the right place or your TFTP command is wrong.
PapaXDragon wrote:2) I also tried the video and I couldnt make it work unless im missing something. i dont know if i need to input a password or what else.
What didn't work? The video? TFTP?
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
Here's an embedded link to the video.
Different device, but the approach is the same.If you have problems, then a complete "printout" of the TFTP session might offer some clues.
- PapaXDragonMay 30, 2021Tutor
sorry its been a while.
so when i try the tftp video i do everthing correct but when i click update i get this message " unabel to get responses from server"
and when i do the cmd ttfp one it gives me this message "tftp: cant read from local file'R7000P-V1.3.2.134_10.1.66.chk' "
so i feel like im doinging soemthing wrong??
