PapaXDragon
May 23, 2021Tutor
R7000p stopped working
so a little context, got this used so its not orginal. i dont have the box it came with nor any of the manuals. So i was playing video games and i noticed that my internet was slow and it wasnt c...
- May 30, 2021
HOLY COW!!! IT FIXED IT!!!!
So this is how i ended up doing it
i took the downloaded file and moved it from my actual desktop to ThisPC> Local Disk (C:)> users> CarlJ> Desktop. and plased it there.
from there i followed this link https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
and from there i followed the instructions and it flipping worked.
I just wanna say thank you guys so much for the help!! stay safe with Coiv-19
May 23, 2021Guru - Experienced User
try using tftp or nmrpflash.
are you on windows? if so, follow this guide
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
PapaXDragon
May 23, 2021Tutor
thanks for the reply
i tried all the steps on (https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP)
1) but couldt make it past step 12 it said that it 'could not read from local file'. im not sure what to do after that?
2) I also tried the video and I couldnt make it work unless im missing something. i dont know if i need to input a password or what else.
- PapaXDragonMay 23, 2021Tutor
i also enabled tftp
also i dont know how to use the git hub one that one seems too complex for me
- michaelkenwardMay 24, 2021Guru - Experienced User
That can happen if the firmware file isn't in the right place or your TFTP command is wrong.
PapaXDragon wrote:2) I also tried the video and I couldnt make it work unless im missing something. i dont know if i need to input a password or what else.
What didn't work? The video? TFTP?
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
Here's an embedded link to the video.
Different device, but the approach is the same.If you have problems, then a complete "printout" of the TFTP session might offer some clues.
- PapaXDragonMay 30, 2021Tutor
sorry its been a while.
so when i try the tftp video i do everthing correct but when i click update i get this message " unabel to get responses from server"
and when i do the cmd ttfp one it gives me this message "tftp: cant read from local file'R7000P-V1.3.2.134_10.1.66.chk' "
so i feel like im doinging soemthing wrong??
also do you have to make your modem and your router under the same ip address?
Cause im in Canada, and im using shaw and from what i read, i dont think i can change it??
