Burrahobbit
Sep 29, 2021Tutor
R7000P Suddenly Stopped Working
This evening my Nighthawk R7000P suddenly stopped working, it has a solid amber power button that persists indefinitely. None of the other LEDs are lit except for the WiFi radio LED, which is a solid...
Sep 29, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Burrahobbit
Sep 29, 2021Tutor
The TFTP method was unsuccessful because I couldn't get the router into the "ready" state the guide describes with the flashing power button. I was able to successfully use nmrpflash however, but the problem persists. The router won't even respond to the reset button, even an attempt at a factory reset.
- plemansSep 29, 2021Guru - Experienced User
try using nmrpflash to flash an older firmware.
- BurrahobbitSep 29, 2021Tutor
How much older? I've tried with both the 1.3.3.142 and the 1.3.3.140 so far.
I've tried with multiple older versions of the firmware, all the way back to 1.0.0.44, and the problem seems to persist.
could be a hardware failure. How old is it?
Still within warranty?
