Burrahobbit
Sep 29, 2021Tutor
R7000P Suddenly Stopped Working
This evening my Nighthawk R7000P suddenly stopped working, it has a solid amber power button that persists indefinitely. None of the other LEDs are lit except for the WiFi radio LED, which is a solid...
Sep 29, 2021Guru - Experienced User
No. netgear doesn't sell replacement power supplies.
It might have gotten swapped with your modem. I've seen that happen.
You can use a power supply with MORE amps but less will cause instability.
so maybe during a prior move/power off/something, maybe they got swapped.
Burrahobbit
Sep 29, 2021Tutor
They weren't swapped. The power supply is labeled "Netgear" and our modem is of a dfferent brand. It's definitely the power supply that was sold with our router.
