Ericx566
Feb 10, 2022Aspirant
R7000P unable to output 1000m @ lan port
My ISP is provicded 1000m as i tested( direct plug the wire to the provided modem, and the speed test was 9xx mps) however, onve i connected my R7000P to the modem, the lan from R7000P output on my P...
Feb 10, 2022Guru - Experienced User
What modem/ont are you connecting to?
What firmware is on the router?
How are you testing speeds?
What device are you testing speeds on?
Have you tried a factory reset/reinstall on the r7000P?
- Ericx566Feb 10, 2022Aspirantmodem provided by isp
latest firmware
tested on ps5
tried rest R7000P
using cat5e cable- plemansFeb 10, 2022Guru - Experienced User
Ericx566 wrote:
modem provided by isp----what modem? Model is key.
latest firmware---and which version is it? a number helps more than the "latest" as sometimes its not or the latest has issues.
tested on ps5----try on a hardwired pc/laptop. The ps5 doesn't always choose the best server.
tried rest R7000P
using cat5e cable- Ericx566Feb 11, 2022Aspirant
but the test is running on PS5 with direct lan wire is 9xx mbps but go through router, only have 18xmbps
my firmware is R7000P-V1.3.3.142_10.1.75
my modem is NOKIA G-240G-C
