Ericx566
Feb 10, 2022Aspirant
R7000P unable to output 1000m @ lan port
My ISP is provicded 1000m as i tested( direct plug the wire to the provided modem, and the speed test was 9xx mps) however, onve i connected my R7000P to the modem, the lan from R7000P output on my P...
Ericx566
modem provided by isp
latest firmware
tested on ps5
tried rest R7000P
using cat5e cable
latest firmware
tested on ps5
tried rest R7000P
using cat5e cable
Feb 10, 2022Guru - Experienced User
Ericx566 wrote:
modem provided by isp----what modem? Model is key.
latest firmware---and which version is it? a number helps more than the "latest" as sometimes its not or the latest has issues.
tested on ps5----try on a hardwired pc/laptop. The ps5 doesn't always choose the best server.
tried rest R7000P
using cat5e cable
- Ericx566Feb 11, 2022Aspirant
but the test is running on PS5 with direct lan wire is 9xx mbps but go through router, only have 18xmbps
my firmware is R7000P-V1.3.3.142_10.1.75
my modem is NOKIA G-240G-C
- plemansFeb 11, 2022Guru - Experienced User
And when the test is running throuogh the router, it could be choosing a different server.
its why I'd recommend trying a pc/laptop and hardwiring in. That allows you to run the speedtest in the windows app or browser and you can change servers.
- Ericx566Feb 11, 2022Aspiranti go to cs service in hk, the tech guy show me that the port is ok with computer/laptop.
however, i still encouter low speed for my ps4. so what should i do with r7000p connecting ps5 ? or should i accept this defect that r7000p cant work with ps5
