dav0dav0
Mar 07, 2023Guide
R7000P very slow to serve internet, timeouts with just one real user -- solved?
I've got a Nighthawk in a pretty unusual configuration -- there's older Netgear wifi router and a mesh network station within a foot of the Nighthawk, and I'm using ReadyShare. I've been able to sta...
- Mar 14, 2023
Ho boy, are you going to love this...
Discovered that there is some sort of weird interaction between iTunes and Firefox, when running at the same time doing almost nothing. Some sequence of packets on certain web pages evidently confounds the router and makes it lose track of reality. I have no specific evidence, but suspect this is the result of tracking code and scripts buried in places like Youtube, Facebook, and elsewhere.
Running iTunes 12.12.7.1 and Firefox 110 64 bit on Windows 10 pro. Symptoms are basically the same with WMM, Bearmforming, airtime fairness, or MU-MIMO enabled or disabled
If I have iTunes and Firefox doing nothing-burger activities (playing songs hosted on Netgear's Readyshare disk, sitting on Google's home page), everything runs fine for hours. But the moment I start using the browser for anything more interesting, I'll have maybe 10 minutes before the network dies. Once it's sickly, if I kill the browser, the router comes back to life all by itself after a minute or so. 100% repeatable, even with all of Facebook's plugins disabled.
If I do the same browsing routine with the Edge browser, I can go for hours with no problem.
So I'm pointing the finger at Firefox.
michaelkenward
Mar 08, 2023Guru - Experienced User
dav0dav0 wrote:
Successfully updated firmware to V1.3.3.154_10.1.86
Ran fine for a few hours, but then had an incident with the same symptoms:
That raises another question that I should have asked earlier, what modem sits in front of the router. Make and model, not something like "ISP's cable modem".
dav0dav0
Mar 08, 2023Guide
Arris SB6183
ISP is Comcast, I can get around 500 Mbps via wired connection
Netgear logs don't show anything unreasonable before/after slowdown.
- michaelkenwardMar 08, 2023Guru - Experienced User
dav0dav0 wrote:
Arris SB6183
Bog standard modem. Nothing fancy in there to complicate matters.
