Dewey3's avatar
Dewey3
R7000P vs R8000P Number of Device Connections
Greetings all. Our internet runs from the cable modem (Netgear CM1000, but not relevant to the question) to a R8000P on the first floor, then to our previous R7000P in the basement which now serves a...
  • plemans's avatar
    Oct 05, 2021
    You'll be fine.
    that amount is the "recommended" based on its wifi capabilities. Hardwired you can have a lot more connected.
    And the R8000P will be hardwired in.
