jollygreen
Apr 24, 2020Aspirant
R7000P will not retain most configuration changes
I have a new R7000P which is newly set up and working. My existing network is in the subnet 192.168.8.0/24 and I have configured the router to have an IP address of 192.168.8.1 However, when I tr...
- May 02, 2020
I finally resolved the problem.
I tried to change the LAN address of the Nighthawk R7000P from the address 192.168.8.1 to the default 192.168.1.1 (Advanced > Setup > LAN Setup) - but this setting change again would not be saved. I tried to change the Internet settings (Advanced > Setup > Internet Setup) to use the ISP provided DNS settings, and then I got the strange error "MAC address invalid format" - even though I was not changing the MAC address of the router, the MAC address was valid and in the correct format - a very strange error when trying to change the DNS settings to default/automatic.
So, I realised that something is really wrong - and I could not change the settings to fix it, so I had to do a factory reset.
After the factory reset, I again set the router's IP to be on my network (change to 192.168.8.1) and the same problem happened - could not change any settings after the IP was changed away from the default of 192.168.1.1
After a second factory reset of the R7000P, and completely re-addressing all my other equipment, including manual configuration of all my other devices that need to communicate with each other (which took around 5 hours), I have now moved everything to the 192.168.1.0/24 network and finally I am able to make configuration changes to the router, and it retains the settings!
Very strange - has anyone else had problems with changing to a network other than 192.168.1.x?
jollygreen
May 02, 2020Aspirant
antinode
May 02, 2020Guru
> [...] has anyone else had problems with changing to a network other
> than 192.168.1.x?
I have a couple of friends with R7000 (_not_ R7000P) routers
(unknown, older-than-latest firmware). One uses "192.168.4.*", the
other uses "192.168.8.*". No problems.
> [...] I have now moved everything to the 192.168.1.0/24 network [...]
That was the coward's way out, but it's nice (for you) that it
worked.
