Chele's avatar
Chele
Follower
Jan 09, 2017
R7100
When I connect my IPhone 6s it shows my router/internet. I click it, a check mark is next to the NetGear name but underneath it says in orange, No Internet connection. I have contacted my phone provid...
  • JamesGL's avatar
    Jan 11, 2017
    Hi Chele,
    If other devices are working fine then the problem might be with your iPhone. Try connecting it on a different network, if still the same, contact Apple.
