Thilo
Jul 20, 2021Aspirant
R7100LG GSM Modul defekt?
Hi, i get no more mobile connection with SIM card. SIM card is working in other modems. I take the router in factory reset but no result. Because it dont works i make a firmwareupgrade to V1.0.0....
DarrenM
Jul 20, 2021Sr. NETGEAR Moderator
Have you tried to revert the firmware to see if those settings start working again?
DarrenM
- ThiloJul 21, 2021Aspirant
Hi DarranM,
Thank you for feedback and info.
I test it with the old firmware downgrade to V1.0.0.52 and same Error message while downgrade:
LTE MODEM UPGRADE FAILED
After reboot same situation: Adjusting for "Mobile Broadnad Settings" are grey and connot adusted.
- DarrenMJul 21, 2021Sr. NETGEAR Moderator
Hello Thilo
I want to get you to support to work on this issue I have sent you a PM.
DarrenM
