Thilo
Jul 20, 2021Aspirant
R7100LG GSM Modul defekt?
Hi, i get no more mobile connection with SIM card. SIM card is working in other modems. I take the router in factory reset but no result. Because it dont works i make a firmwareupgrade to V1.0.0....
DarrenM
Jul 20, 2021Sr. NETGEAR Moderator
Have you tried to revert the firmware to see if those settings start working again?
DarrenM
Thilo
Jul 21, 2021Aspirant
Hi DarranM,
Thank you for feedback and info.
I test it with the old firmware downgrade to V1.0.0.52 and same Error message while downgrade:
LTE MODEM UPGRADE FAILED
After reboot same situation: Adjusting for "Mobile Broadnad Settings" are grey and connot adusted.
- DarrenMJul 21, 2021Sr. NETGEAR Moderator
Hello Thilo
I want to get you to support to work on this issue I have sent you a PM.
DarrenM
