RJSPro
Jun 09, 2021Follower
R7200 (61X197BRA242B)
We purchased an R7200 Nighthawk WiFi Router. It comes with zero support and has been 100% useless in improving our Spectrum Internet service.
We have a ranch home that is under 3,000 square feet. All devices are relatively close to our Nighthawk and anything in another room has a terrible connection even though nothing is more than 20 steps away from the Nighthawk.
What boosters or other solutions do you recommend?
Thank you.
1 Reply
What are the walls in the home made from?
What devices are you using?
what actual speeds are you getting over wired, 2.4ghz wireless, and 5ghz wireless?
What modem/gateway do you have it connected to?
