ezrollin
Feb 01, 2021Aspirant
r7200 static routes and AP
I'm having trouble when I get on my ATT Fiber router from being able to access my private LAN on my Nighthawk. Am I not seting up my static route correctly?? Also, I...
ezrollin
Why cant I see my pictures???
Also I'm interested in turning this wired nighthawk into an AP of my ATT fiber gateway router but I dont see any way to
do it on the Router Selection type screen (Router/AP/Bridge mode screen)
Feb 01, 2021Guru - Experienced User
Pictures have to be approved by a moderator and that can take several days.
You can click "choose file" and attach them.
to put the R7200 in access point mode, you'd need to login through the browser and not with the app. Have you tried that route
- ezrollinFeb 01, 2021Aspirant
Again, I cant get the app to work. I only use a browser. Thanks for the info
- michaelkenwardFeb 01, 2021Guru - Experienced User
What does that mean? What happens when you try?
Which app? Android? iOS? Nighthawk? Genie? (That's won't work now.)
