DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns
"Attempting to connect to Netgear Server. Please Wait..." --
Then it returns:
| A New Detection Database is Found. Do You Want to Upgrade to the New Version Now? | |
| Current Detection Database Version: | v1.46 |
| New Detection Database Version: | v1.80 |
Clicking on "YES" the router says Attempting to connect to Netgear Server. Please Wait... -- It flashes once (statement goes away - then returns to same "Attempting to connect to Netgear Server. Please Wait...") -- Then it says could not download database and I get the "Database could not be downloaded from the NETGEAR server. Please check your Internet connection." error message
Do I need to change a setting to get this to work?
The latest firmware 1.0.0.52 should fix it.
- WesSAspirant
I have the same issue. Already at firmware version V1.0.0.46_1.0.13. QOS performance database is version v1.46,1.0.26 released 2015/03/08.
- SWKerrAspirant
I have the same problem where Current Performance Optimization Database on Router is stuck at Version: v1.46,1.0.26
Is there a soltution for this issue. Currently I have found that the QoS feature is usless with the current setup. Setting a priory for a PC or device is pointless. The lowest PC on the priorty list will get all the bandwith compared to a highest Xbox One.
- hcschaubAspirant
I have the same issue as reported by the community unable to update QOS Database. I am using the latest firmware V1.0.0.46_1.0.13.
- pb1908Aspirant
Literally just bought this router today and unpacked/updated to V1.0.0.46_1.0.13. Can I get the beta link so I can try and experience full functionality knowing this vulnerability is patched and even update the performance enhancement DB to v1.80?
- EricVAspirant
I too need it.
- ElaineMNETGEAR Employee Retired
Kindly check your inboxes.
- palladiumllcAspirant
Hello,
Could I receive the beta as well?
Thank you
- Big_RAspirant
I am having the same problem. Current firmware V1.0.0.46_1.0.13, current QOS DB v1.46,1.0.26.
Wold you please send me a copy of the beta QOS. Thanks in advance.
- mikefromnjAspirant
Same issue here. Can you please send me the required update. Thanks
- SLIMSHADYAspirant
I am also experiencing this issue may i get this fix as well?
- pareddyAspirant
I too could use a copy of the software. thank you!
- blackmagik01AspirantI need a copy of the beta also. I've been fighting with this situation for 2 months now. Thank god I found this forum section.
blackmagik01 It should be in your inbox now.
- leetolInitiate
Please send the beta link. Thanks!
- sheikh73AspirantHi ElaineM
I am having the same issue. I have Firmware Version 1.0.0.46 but database is not updating. Can you please send me the link to beta fw.. Thanks
