tomesco
Oct 19, 2022Aspirant
R7300 won't connect to internet through Arris modem
Hi, hoping someone can help: I have the R7300 connected via ethernet to an Arris modem (Cox cable) and am unable to establish an internet connection. i have tried cloning the mac address from a prev...
tomesco
Oct 20, 2022Aspirant
Thanks, I did all of that and was able to get into the browser config tool while having the ethernet plugged into the WAN port on the router. I get an IP and subnet etc and all the lights are white, but I still can't get to the internet. I called Cox and they were having issues sending commands to the modem, so at this point I think the real issue is with either Cox or with the Arris Modem. I appreciate the help, if they can't resolve it, i'll post again.
Oct 21, 2022Guru - Experienced User
Start with removing any amplifiers, signal attenuators, or splitters from the coax line.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
