robtheath
Aug 12, 2022Follower
R7350 AC2400 Firmware update reverts after completion
I am using the Nighthawk app on Android to update the firmware on my R7350 A2400 Nighthawk router. The current firmware version is v1.2.0.74. The app indicates that the new version available is eith...
michaelkenward
Aug 13, 2022Guru - Experienced User
robtheath wrote:
A side issue, I can't reach the router's Web interface on http://www.routerlogin.net or 192.168.1.1 via WiFi or Ethernet.
That might not be the "side issue" that you think. If you can't get in there then the advice to do a manual update won't work.
Start with this problem and then worry about the firmware.
If the link that Kitsap provided doesn't get you out of that hole, it might be a good idea to tell us what the modem/gateway is between the router and the Internet.
