chickenwing100
Apr 29, 2024Aspirant
R7350 and R6300 WiFi is faster than Ethernet
I have a 500mbps plan. I have my R7350 as my Router and it is connected to my R6300 which is set up as an access point with a cat 6 cable. Both give up to the 500 speed on WiFi but when I connect any ...
chickenwing100
Apr 30, 2024Aspirant
R7350 is on V1.2.0.92_1.0.1
R6300 is on V1.0.2.80_1.0.59
Modem Model is ES2251 from spectrum it's just a regular modem, no lan ports on the back
michaelkenward
May 01, 2024Guru - Experienced User
They are up to date.
Have you been through the setup process methodically? Reset each device and restart things in the expected order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
You should also check that the cables are good with decent connections.
Start with the router and sort that out before worrying about the access point.
How are you testing wired speeds? That is another link in the chain that can cause problems.
- chickenwing100May 01, 2024AspirantI tried this I unplugged everything everything reconnected fine except my r6300 which is my access point when I plug it back in the power light flashes green(I'm pretty sure it's bricked because it's old). I decided to use the Ethernet cable that connects from router to my PC and I get the full speed so I think it was my access point causing the problem so I will buy a new one.
- michaelkenwardMay 02, 2024Guru - Experienced User
chickenwing100 wrote:
I tried this I unplugged everything everything reconnected fine except my r6300 which is my access point when I plug it back in the power light flashes green(I'm pretty sure it's bricked because it's old).Old doesn't necessarily mean bust. Did you try it with as different power adapter to rule that out? The one on the R7350 should be the same. Check the labels on the devuces and their adapters.
Have you reset the R6300 and put it back into AP mode? That's best done with the R6300 disconnected from the network and a direct connection to a PC.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
If the R6300 still plays up, then you may be able to kick it back into action.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
- chickenwing100May 02, 2024Aspirant
I managed to recover it using TFTP, but now I am only getting up to 300 on ethernet again.
I am using Speedtest by Ookla and a Playstation 5 to test. WIFI is around 500 and ethernet is around 300 for both
