NetNight2022
Jun 17, 2022Follower
R7350 Firmware
Trying to do the auto firmware update from v1.2.0.90 to v1.2.0.92 and it keeps failing. Since the update did not complete, I am unable to access the Internet, anyone of a solution?
Jun 17, 2022Guru - Experienced User
Factory reset the router and setup from scratch.
What browser are you using? Try MS Edge or Firefox.
Be sure to unpack the .zip file to reveal the actual FW file to be sent to the router using the routers web page.
Turn off and unplug modem.
Turn on computers and rest of network.
