Timlab55
Dec 24, 2021Guide
R7350 Married to a AT&T BGW200-700
I'm going to make this as short as possible. If anyone who is reading this knows about the BGW200-700 Gateway/Router will know that the types of services it offers is very low class. Besides gettin...
- Dec 25, 2021
Be sure to make a back up configuration to file for safe keeping. Saves time if a reset is needed.
Timlab55
Dec 25, 2021Guide
Plemans your great! The first thing I turned off was QoS. On everything including the WiFi. Wow I when from 300 MB/s to 850 MB/s. S Where should I send the check to?
Dec 25, 2021Guru - Experienced User
Lol. You can just set it as 'solved'.
Glad it got it up and working better for you :)
Merry Christmas!
