dcblakedvm's avatar
dcblakedvm
R7350
Hi,
I am frustrated. I was originally to login to the router to formulate a schedule for the router to turn off and on. Now I have lost the ability to do so. As far as I'm aware you cannot do this from the nighthawk app. When I try to go to routerlogin.net or .com, it defaults to the Netgear page. I have followed troubleshooting and deleted chrome history from all time and it hasn't helped. I have tried using chrome, edge, or mozilla and no progress. when I enter 198.162.1.1 all I get is an error. I have tried turning off my firewall and nothing has happened. I have tried to factory reset the router and that didn't work either. I would think performing a simple function as this shouldn't be this difficult. I think it is ridiculous to have to pay tech support for something like this. Any ideas would be appreciated.
  • FURRYe38's avatar
    Are you referring to the R7350?
    Try a factory reset on the router by pressing the reset button for 10 seconds then release. With one wired PC and web browser, navigate to 192.168.1.1...see if you can access the setup wizard and complete it.
