WFHg
Jul 31, 2022Aspirant
R7400 disconnects from Internet on every WAN DHCP lease renewal
Configuration
Netgear Nighthawk R7400 router connected to Surfboard SB6141 cable modem
Router firmware: V1.2.0.92_1.0.1
Problem
The router disconnects from the Internet for a number of seconds every time it renews the lease for the *WAN* IP address from my ISP. LAN-side traffic does not appear to be affected. Since my ISP is currently giving only one- or two-hour leases, the router disconnects numerous times per day, disrupting my work often.
The problem can also be reproduced at will by selecting
Advanced-Home->Connection-Status->Renew in the router BUI.
Each time the problem occurs, the router's WAN connection LED changes from white to amber, then back to white, and a pair of lines like these is written to the router log:
[Internet connected] IP address: xx.xx.xx.xx Sunday, July 31,2022 10:28:37
[Internet disconnected] Sunday, July 31,2022 10:28:35
Although the above messages are only a couple of seconds apart, the user disruption is noticeably longer.
I've experienced this problem for a number of months, including while running the two prior versions of the router firmware.
I've factory-reset the cable modem and done multiple network resets to no avail.
I've seen reports in the community forums of similar issues with other router models, sometimes diagnosed to router firmware issues.
What is the CAT# lan cable between the modem and router? CAT6 is recommended.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlHas a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
Shame the ISP renews WAN IPs every couple of hours. Really not need for this but I guess if thats what they do.
Might try a different router as a test to see if something different does same thing or not.
- WFHgAspirant
Thank you for your reply.
The cable between the modem and the router is CAT 5, but it's only 6ft long. The coax I can see (because it's not in the crawl space) leading to the modem all appears good. The signal quality seems to be fine, whereas the DHCP-renewal-disconnect problem seems to be protocol/logic related.
I've previously factory-reset both the modem and the router and reset the network more than once, but I factory-reset the modem again today, then reset the network in the specified sequence. The Internet disconnection on DHCP renewal problem was present after the network reset with the router in its factory configuration and is still present after I reconfigured the router to my settings.
- WFHgAspirant
I said:
"I've previously factory-reset both the modem and the router and reset the network more than once, but I factory-reset the modem again today, then reset the network in the specified sequence."
I actually factory reset the *router*, then reset the network in the proper sequence.
