ObiRichKanobi
Nov 23, 2024Tutor
R7400 Problem with Readyshare and new Win 11 laptop
I just purchased a new Win11 laptop and can't get it to connect to the drive I have plugged into my router so I can map a drive. I have 3 other computers (2 Win11 and 1 Win10) that see it no problem...
- Nov 28, 2024
It's finally working. After probably 12 hours of doing Google and MS KB searches I gave up and went to Microsoft support. We did some preliminary stuff, and then I gave him control. Watched him check and recheck things that I'd already done for an hour. Finally, he said let's reset the network. Did that through the control panel, and when things booted up, the router showed up via IP, and so did the shared folder. Simply mapped it, and now all is good. I want to say thanks for all the good suggestions here.
Kitsap
Nov 25, 2024Master
ObiRichKanobi wrote:Yes, my network is set to private. My Xfinity gateway is not set to bridge mode; I run two WIFIs off that. My Netgear is plugged directly into the gateway, and also is not in bridge mode, as use the WIFI off that as my primary connections as it's upstairs and we get better signal.
This is really baffling me...I have a Win10 and there's two other Win11 laptops that all see it and have it mapped just fine. đ©
Your configuration is known as Double Nat, and it causes problems with two devices on the same network attempting to perform routing functions. Your Xfinity gateway and your R7400 are fighting each other for control of your local network.
See here: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
Here are some links for suggestions on a configuration fix to resolve the issue.
I would recommend you strongly consider configuring your R7400 as an access point and let your gateway perform the routing functions for your LAN. That way you can have Wi-Fi being broadcast from both your gateway and your router configured as an access point.
Some background articles: https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
michaelkenward
Nov 25, 2024Guru - Experienced User
Kitsap wrote:I would recommend you strongly consider configuring your R7400 as an access point and let your gateway perform the routing functions for your LAN. That way you can have Wi-Fi being broadcast from both your gateway and your router configured as an access point.
That really is the best option, especially with something like the now ageing R7400.
Even in AP mode you can use the USB ports for storage.
You can make life easier by fixing the IP address of the R7400 or, if this is possible, reserving an IP address for it on the modem/router.
There is an alternative that would let you put both devices in router mode, it is to use the "DMZ" on the modem/router. But I would avoid that unless you really need to do things with the R7400 that won't work in AP mode.
Just another user with time on their hands.
- ObiRichKanobiNov 25, 2024Tutor
I checked the R7400 and it's already configured as an access point.
- KitsapNov 25, 2024Master
ObiRichKanobi wrote:I checked the R7400 and it's already configured as an access point.
So far, everything points back to the new Windows 11 machine where you use the little readyshare applet and get a "Windows has returned an unspecified error" message.
Do you know if the operating systems on your Windows machines, both 10 and 11, are the Home version or the Pro version or a combination? Have your Windows 11 machines been updated to version 24H2?
Using a router with a drive installed as a Network Assigned Storage (NAS) device does have its limits. That is why dedicated NAS boxes connected to the LAN via Ethernet are popular.
<<Do you know if the operating systems on your Windows machines, both 10 and 11, are the Home version or the Pro version or a combination? Have your Windows 11 machines been updated to version 24H2?>>
All three are Windows Home. The two older ones (that work) are 23H2, the new one is 24H2.
