Spliffa
Apr 29, 2022Aspirant
R7450 2600 smart
Router stopped working out of the blue, have rebooted, reset, tried new setup, hard reset for 30 secs and all I have is a blinking white power light, won’t change
- Apr 29, 2022
Last resort would be to see if Recovery works:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpawIf not, router needs replacing I would guess.
Apr 29, 2022Guru - Experienced User
Can access 192.168.1.1 with a wired PC?
Try swapping out the power adapter with another with same volts and amps specs.
if this doesn't fix, router may need to be replaced.
- SpliffaApr 29, 2022AspirantSwapped adapter, no change, when plugging in original power light is solid white, but second light is blinking white but won’t boot the rest of the way
- FURRYe38Apr 29, 2022Guru - Experienced User
- SpliffaApr 29, 2022AspirantI appreciate the assistance, I think you may be correct, a new unit seems necessary. Thank you for your help
- SpliffaApr 29, 2022AspirantBasically back to square 1, looks like I’ll be picking up a new router
