Spliffa
Apr 29, 2022Aspirant
R7450 2600 smart
Router stopped working out of the blue, have rebooted, reset, tried new setup, hard reset for 30 secs and all I have is a blinking white power light, won’t change
- Apr 29, 2022
Last resort would be to see if Recovery works:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpawIf not, router needs replacing I would guess.
Spliffa
Swapped adapter, no change, when plugging in original power light is solid white, but second light is blinking white but won’t boot the rest of the way
Apr 29, 2022Guru - Experienced User
- SpliffaApr 29, 2022AspirantI appreciate the assistance, I think you may be correct, a new unit seems necessary. Thank you for your help
