Postfunk
Mar 09, 2022Guide
R7450 allow 2.4 ghz devices
Netgear Nighthawk AC2600 smart wifi router Model R7450 I have two different models of robot cleaners which require 2.4ghz to accept the WIFI password. The error given in both cases is: “Incorrect ...
Mar 09, 2022Guru - Experienced User
You can simply disable smart connect. You just need to make sure to have your phone on the 2.4ghz during setup of the vacuums.
Postfunk
Mar 10, 2022Guide
Thanks for the response. I hve an iPhone and it does not allow the manual set of ghz
- plemansMar 10, 2022Guru - Experienced User
fully aware of that.
So disable smart connect as I'd advised. Then you name the 2 networks different and you can manually choose which to connect to with your phone. If you're planning on re-enabling smart connect, make sure the 2.4ghz (that youre setting the device up on) is the one with the ssid that the network name will be.
- PostfunkMar 13, 2022Guide
Thank you, I have to wait until Monday to pursue
