BENNY1864
Apr 05, 2022Initiate
R7450 BOOT PROBLEM
hi so when i turn my router on it lights up the wifi button white for a couple of sec then goes off and power light stays amber any help would be awesome thanks
Charlesfz6
Apr 05, 2022Aspirant
Mine locked up after attempting to update firmware to the latest version ....90 through the app. Will not factory reset. Seems bricked.
- wcalifasApr 05, 2022Prodigy
try a different power adapter and see if that fixes it. Amber light might mean the power adapter is bad.
