tkvoice
Feb 02, 2026Aspirant
R7450 Bridge Mode Configuration
I am new to Bridge Mode I have a R7450 router and have managed to place it in bridge mode. I chose to connect to 5GHz SSID on another WiFi router and got it to connect. Wired devices connected to ...
Feb 02, 2026Guru - Experienced User
tkvoice wrote:f I am bridging using 5GHz radio is there a way to use the 2.4GHz radio (that is currently doing absolutely nothing) to work as an Access Point? That way wireless devices in the remote area can use the bridge too.
No.
There is no description in the manual about what can be used on the RJ45 ports. Can the WAN RJ45 port be used for anything while in bridge mode? Or is it just the 4 LAN ports I can use?MIght see if mirror WAN to LAN is seen on the Routers debug page. If not there, then only the LAN ports work in bridge mode.
Once in Bridge Mode how do I view the WiFi SSID I am currently connected to or chose a different WiFi connection?
Should be seen on the status page on the bridge router.
