tkvoice
Feb 02, 2026Aspirant
R7450 Bridge Mode Configuration
I am new to Bridge Mode I have a R7450 router and have managed to place it in bridge mode. I chose to connect to 5GHz SSID on another WiFi router and got it to connect. Wired devices connected to ...
CrimpOn
Feb 02, 2026Guru - Experienced User
It would not be a difficult experiment to conduct.
- Does the SSID of the R7450 appear to WiFi devices as an available network?
- If so, what happens when a device attempts to connect to it?
tkvoice
Feb 03, 2026Aspirant
No
When in bridge mode the R7450 does not present a SSID. It is basically a WiFi device so you have to choose either 2.4Ghz or 5Ghz to connect (just like your cel phone).
I am disappointed in "Bridge Mode" it is a minimal design. It wastes 1 of the 2 radios. Too bad they didn't put a litter more effort into adding features like:
- Using both radios for the bridge for redundancy in case one frequency is having trouble.
- Allow you to use the other radio act as an AP
- FURRYe38Feb 03, 2026Guru - Experienced User
Brige mode is only meant for a connection with one frequency. The other radios can't not be used as would cause some interferences and how the system worked. Wireless bridge mode is only intended to work as a client mode configuration with one radio, either 2.4 or 5Ghz. How this has been for a long time. Seen with other mfr routers that support bridge mode. I have an ASUS router that does same thing. Pick one radio to connect with, all others are not used. Bridge mode has had a limited use for the average user and NG seems to have no longer supported this in there newer class routers. So bridge mode maybe doing away for some.
