Imieam
Dec 04, 2020Aspirant
R7450 devices do not recognize router
My ISP (Spectrum) equipment recognizes the new router but my devices do not. Also in Nighthawk app the set up does not recognize the QR code’s on back of the router. How do I get my wi-fi up and runni...
Dec 04, 2020Guru - Experienced User
what modem do you have it connected to?
You can connect a pc/laptop to it via ethernet and go through setup that route. Have you tried that method?
- ImieamDec 04, 2020AspirantModem supplied by Spectrum, & they confirm their connections see the Router as available. My laptop does not have Ethernet cord port so that is not an option.
- plemansDec 04, 2020Guru - Experienced User
the label on the router should show the default ssid/password you can use for setup.
You can also try factory resetting it in case someone else already set it up.
Push and hold reset for 7-15 seconds while its powered on.
- ImieamDec 04, 2020AspirantIs this the login you are referring to? Router login.net User name: admin password: password
