Out_side
Mar 22, 2023Follower
R7450 Error Code 8066
Cannot login I'm getting an Error Code 8066 on my iPad 8th generation, IOS Version 16.31
michaelkenward
Mar 22, 2023Guru - Experienced User
Is that using the Nighthawk app? (Hard to tell with so little detail.) What tgrws that error code?
You can also get into the browser graphical user interface (GUI) using a browser on your mobile device.
- Sign into the router's wifi
- Open a browser
- Try to access routerlogin.net or 192.168.1.1
It might also help if you told us about the modem/gateway/ONT that connects your router to the Internet.
