cwalk
Apr 08, 2022Aspirant
R7450 firm update no wifi now
Update started and now wifi won’t connect and power button flashes And don’t know how to fix it. Not good with tech stuff and router was bought last July
Apr 09, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
if that doesn't work and you bought it in january, then you should be in your warranty period if you bought it new.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- cwalkApr 09, 2022AspirantThanks for info..however it was bought last year in July..8-9 months ago. With no internet I can’t use my computer only my iPhone with LTE…will that work?
- plemansApr 09, 2022Guru - Experienced User
to uses tftp/nmrpflash, you have to be hardwired into the router. Watch the video/read the guides. They go over how to use it.
If you can't do that, you can open a support case with netgear.
From there you can start the support process. Keep in mind that its only free for the first 90 days.- wcalifasApr 09, 2022Prodigy
You got a laptop or desktop computer you can use? Like it was mentioned before it has to be hardwired to one of the four ethernet ports on the back of the router. You'll also need to download the firmware file for your router from the netgear website.
