Shiverman45
May 03, 2023Aspirant
R7450 how do I access and change the firewall
My wife recently started working for a company based out of Germany and they sent her a laptop with their specific software installed on it. Our router won't allow the software access and the company...
May 03, 2023Guru - Experienced User
What modem/gateway do you have?
Have you tried give the laptop a reserved IP address and then putting it in the netgears DMZ?
Shiverman45
My modem and router are all in one. I'm not sure how to do either of those things you mentioned.
- plemansMay 03, 2023Guru - Experienced User
The R7450 isn't a modem/router. Its a router-only device.
So its connected to something,what is that?
The manual would be a good place to start with what I recommended.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.- Shiverman45May 03, 2023Aspirant
I'm reading the manual currently and attempting to log in to the router from routerlogin.net
I don't know what else the router is connected to. I bought the router and that's it. Plugged in the power and ethernet cable and I have internet. My ISP didn't leave any equipment here when they set us up.
- michaelkenwardMay 03, 2023Guru - Experienced User
Plugged the Ethernet cable into what?
A hole in the wall? A box of some sort?
As plemans says the R7450 is a router. It gets the Internet from somewhere.
